$EE hack
Do you still need one?
XDF
1.110000
DO NOT HAND EDIT!!!! (Trust me)
%%HEADER%%
001000 FileVers ="BJ "
001005 DefTitle ="PCM_EE "
001007 DescSize =0xCDCDCDCD
001006 Desc =""
001010 Author =""
001030 BinSize =0x20000
001035 BaseOffset =0
001200 ADSAssoc =""
001225 ADSCheck =0x0
001300 GenFlags =0x0
001325 ModeFlags =0x0
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63EE
020005 Title ="MAP Threshold To Enable WOT "
020011 DescSize =0xCDCDCDCD
020010 Desc =""
020020 Units ="Kpa "
020100 Address =0x128E2
020200 Equation =1.000000 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63EF
020005 Title ="Cylinder Volume "
020010 Desc =""
020020 Units ="ml/Cyl "
020100 Address =0x12B4E
020200 Equation =8.965625 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F0
020005 Title ="Injector Flow Rate "
020010 Desc =""
020020 Units ="lbs/HR "
020050 SizeInBits =0x10
020100 Address =0x12B4C
020200 Equation =0.038743 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F1
020005 Title ="Cool Thresh For TPS For WOT (HighTemp) "
020010 Desc =""
020020 Units ="Deg C "
020100 Address =0x128E6
020200 Equation =0.750000 * X + -40.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F2
020005 Title ="EGR Enable, Min. MAP "
020010 Desc =""
020100 Address =0x2604
020200 Equation =0.369000 * X + 10.400000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F3
020005 Title ="EGR Enable, Min RPM "
020010 Desc =""
020020 Units ="RPM "
020100 Address =0x2605
020200 Equation =25.000000 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F4
020005 Title ="EGR Enable, Max RPM "
020010 Desc =""
020100 Address =0x2606
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F5
020005 Title ="Fan 1 On Threshold (Low MPH) "
020010 Desc =""
020100 Address =0x264A
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F6
020005 Title ="Fan 1 On Threshold (High MPH) "
020010 Desc =""
020100 Address =0x264B
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F7
020005 Title ="Fan 2 On Threshold (Low MPH) "
020010 Desc =""
020100 Address =0x264C
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F8
020005 Title ="Fan 2 On Threshold (High MPH) "
020010 Desc =""
020100 Address =0x264D
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63F9
020005 Title ="Fan Hysteresis Low Speed (MPH) "
020010 Desc =""
020100 Address =0x264F
020200 Equation =0.750000 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63FA
020005 Title ="Fan Hysteresis High Speed (MPH) "
020010 Desc =""
020100 Address =0x2650
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63FB
020005 Title ="Fan Threshold High Speed (MPH) "
020010 Desc =""
020020 Units ="MPH "
020100 Address =0x264E
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63FC
020005 Title ="Fan 1 On, Oil Temp, (Low RPM) "
020010 Desc =""
020100 Address =0x2654
020200 Equation =0.800641 * X + -40.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63FD
020005 Title ="Fan 1 On, Oil Temp , (High RPM) "
020010 Desc =""
020100 Address =0x2655
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63FE
020005 Title ="Fan 2 On, Oil Temp, (Low RPM) "
020010 Desc =""
020100 Address =0x2659
%%END%%
%%CONSTANT%%
000002 UniqueID =0x63FF
020005 Title ="Fan 2 On, Oil Temp, (High RPM) "
020010 Desc =""
020100 Address =0x265A
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6400
020005 Title ="Fan Enable, (High RPM, High Oil Temp) "
020010 Desc =""
020100 Address =0x2657
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6423
020005 Title ="Fan Oil Temperature Hysteresis "
020010 Desc =""
020100 Address =0x2656
020200 Equation =0.800641 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6424
020005 Title ="Fuel Cutoff Speed "
020010 Desc =""
020100 Address =0x26D7
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6425
020005 Title ="Fuel Resume Speed "
020010 Desc =""
020100 Address =0x26DC
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6426
020005 Title ="Fuel Cutoff, 1st Gear "
020010 Desc =""
020100 Address =0x26D8
020200 Equation =2949120.000000/X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6427
020005 Title ="Fuel Cutoff, 2nd - 6th Gear "
020010 Desc =""
020100 Address =0x26DA
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6428
020005 Title ="Fuel Resume, 1st Gear "
020010 Desc =""
020100 Address =0x26DD
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6429
020005 Title ="Fuel Resume, 2nd - 6th Gear "
020010 Desc =""
020100 Address =0x26DF
%%END%%
%%CONSTANT%%
000002 UniqueID =0x642A
020005 Title ="Error 32, Min Diff. MAP Test Value "
020010 Desc =""
020100 Address =0x20AE
%%END%%
%%CONSTANT%%
000002 UniqueID =0x642B
020005 Title ="Speedometer Scalar "
020010 Desc =""
020020 Units ="Divisor "
020100 Address =0x12DD2
%%END%%
%%CONSTANT%%
000002 UniqueID =0x642C
020005 Title ="Speedometer Scalar, Fraction "
020010 Desc =""
020100 Address =0x12DD4
020200 Equation =0.001953 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x642D
020005 Title ="Speedometer Scalar, (Scan Tool) "
020010 Desc =""
020100 Address =0x288C
020200 Equation =0.000977 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x642E
020005 Title ="Time Between Pulses For 'Stop' "
020010 Desc =""
020020 Units ="msec "
020100 Address =0x12DD6
020200 Equation =0.015259 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x642F
020005 Title ="Min. Coolant Temp. For CAT Protect "
020010 Desc =""
020100 Address =0x1292F
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6430
020005 Title ="Min. Coolant Temp. To Enable C.A.R.S. "
020010 Desc =""
020100 Address =0x26B7
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6431
020005 Title ="Speed Threshold To Enable C.A.R.S. "
020010 Desc =""
020100 Address =0x26B9
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6432
020005 Title ="Speed Threshold To Disable C.A.R.S. "
020010 Desc =""
020100 Address =0x26BA
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6433
020005 Title ="RPM Threshold To Disable C.A.R.S. "
020010 Desc =""
020100 Address =0x26BB
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6434
020005 Title ="%TPS Threshold To Disable C.A.R.S. "
020010 Desc =""
020020 Units ="% TPS "
020100 Address =0x26BC
020200 Equation =0.390625 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6435
020005 Title ="MAP Threshold To Enable C.A.R.S. "
020010 Desc =""
020100 Address =0x26BE
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6454
020005 Title ="MAP Threshold To Disable C.A.R.S. "
020010 Desc =""
020100 Address =0x26BD
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6455
020005 Title ="PROM ID "
020010 Desc =""
020020 Units =" "
020100 Address =0x2017
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6456
020005 Title ="Minimum BLM "
020010 Desc =""
020020 Units =" "
020100 Address =0x274D
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6457
020005 Title ="Maximum BLM "
020010 Desc =""
020020 Units =" "
020100 Address =0x274C
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6458
020005 Title ="Min. Cool. Temp. for Closed Loop "
020010 Desc =""
020100 Address =0x26E3
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6459
020005 Title ="Min Cool Temp for Closed Loop, Cold MAT "
020010 Desc =""
020100 Address =0x26E4
%%END%%
%%CONSTANT%%
000002 UniqueID =0x645A
020005 Title ="BLM Cell RPM Boundary Hysteresis "
020010 Desc =""
020100 Address =0x2745
%%END%%
%%CONSTANT%%
000002 UniqueID =0x645B
020005 Title ="BLM Cell MAP Boundary Hysteresis "
020010 Desc =""
020100 Address =0x2746
%%END%%
%%CONSTANT%%
000002 UniqueID =0x645C
020005 Title ="Speed Pulses Per Driveshaft Revolution "
020010 Desc =""
020020 Units ="Pulses "
020100 Address =0x2889
020200 Equation =0.000916 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x645D
020005 Title ="Low PRNDL Upshift Speed Threshold "
020010 Desc =""
020100 Address =0x2C52
%%END%%
%%CONSTANT%%
000002 UniqueID =0x645E
020005 Title ="Low PRNDL Downshift Speed Threshold "
020010 Desc =""
020100 Address =0x2C53
%%END%%
%%CONSTANT%%
000002 UniqueID =0x645F
020005 Title ="Burst Knock Enable %Diff Air Flow Thresh"
020010 Desc =""
020020 Units ="% "
020100 Address =0x1234D
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6460
020005 Title ="Burst Knock Enable Coolant Temp. Thresh."
020010 Desc =""
020020 Units ="Deg. C "
020100 Address =0x1234B
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6461
020005 Title ="DFCO Enable RPM Threshold "
020010 Desc =""
020100 Address =0x128A4
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6488
020005 Title ="DFCO Disable RPM Threshold "
020010 Desc =""
020100 Address =0x128A5
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6489
020005 Title ="DFCO Enable MAP Threshold "
020010 Desc =""
020100 Address =0x128A7
%%END%%
%%CONSTANT%%
000002 UniqueID =0x648A
020005 Title ="DFCO Disable MAP Threshold "
020010 Desc =""
020100 Address =0x128A8
%%END%%
%%CONSTANT%%
000002 UniqueID =0x648B
020005 Title ="DFCO Disable RPM Decrease Threshold "
020010 Desc =""
020020 Units ="RPM/sec "
020100 Address =0x128AA
020200 Equation =250.000000 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x648C
020005 Title ="DFCO Enable Coolant Temp. Threshold "
020010 Desc =""
020100 Address =0x128AD
%%END%%
%%CONSTANT%%
000002 UniqueID =0x648D
020005 Title ="DFCO Enable MPH Threshold "
020010 Desc =""
020100 Address =0x128AE
%%END%%
%%CONSTANT%%
000002 UniqueID =0x648E
020005 Title ="Low Octane Comp. Attack Gain MAP Enable "
020010 Desc =""
020100 Address =0x1235E
020200 Equation =0.312500 * X + 20.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x648F
020005 Title ="Low Octane Attack Gain Delta MAP Disable"
020010 Desc =""
020100 Address =0x1235F
020200 Equation =0.312500 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6490
020005 Title ="Low Octane Compensation Decay Gain "
020010 Desc =""
020020 Units ="Mult. "
020100 Address =0x12360
020200 Equation =0.003906 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6491
020005 Title ="DFCO Spark Retard "
020010 Desc =""
020020 Units ="Deg. "
020100 Address =0x128C3
020200 Equation =0.500000 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6492
020005 Title ="Maximum Line Pressure "
020010 Desc =""
020020 Units ="psi "
020100 Address =0x2E21
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6493
020005 Title ="Kickdown Mode Enable TPS Threshold "
020010 Desc =""
020020 Units ="%TPS "
020100 Address =0x288F
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6494
020005 Title ="Kickdown Mode Disable TPS Threshold "
020010 Desc =""
020100 Address =0x2890
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64BC
020005 Title ="Spark Advance Table Bias "
020010 Desc =""
020100 Address =0x12086
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64BD
020005 Title ="Spark Coolant Temp Correction Bias "
020010 Desc =""
020100 Address =0x121ED
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64BE
020005 Title ="Min Spark Advance Bias "
020010 Desc =""
020100 Address =0x12063
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64BF
020005 Title ="Spark Reference Angle "
020010 Desc =""
020100 Address =0x12044
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64C0
020005 Title ="Maximum Spark Advance "
020010 Desc =""
020100 Address =0x12045
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64C1
020005 Title ="Knock Retard Enable Coolant Temp. "
020010 Desc =""
020100 Address =0x12306
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64C2
020005 Title ="Vss Diagnostic Enable Min RPM "
020010 Desc =""
020100 Address =0x2117
020200 Equation =0.125000 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64C3
020005 Title ="Min. Coolant Temp. To Enable Air Pump "
020010 Desc =""
020100 Address =0x26AF
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64C4
020005 Title ="Fan 1 On High A/C Pressure Threshold "
020010 Desc =""
020100 Address =0x265D
020200 Equation =1.875000 * X + -18.750000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64C5
020005 Title ="Fan 1 Off High A/C Pressure Threshold "
020010 Desc =""
020100 Address =0x265F
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64C6
020005 Title ="Fan 2 On High A/C Pressure Threshold "
020010 Desc =""
020100 Address =0x2661
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64ED
020005 Title ="Fan 2 Off High A/C Pressure Threshold "
020010 Desc =""
020100 Address =0x2663
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64EE
020005 Title ="Fan 1 Disable MPH, High A/C Pressure "
020010 Desc =""
020100 Address =0x2660
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64EF
020005 Title ="Fan 1 Enable MPH, High A/C Pressure "
020010 Desc =""
020100 Address =0x265E
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F0
020005 Title ="Fan 2 Disable MPH, High A/C Pressure "
020010 Desc =""
020100 Address =0x2664
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F1
020005 Title ="Fan 2 Enable MPH, High A/C Pressure "
020010 Desc =""
020100 Address =0x2662
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F2
020005 Title ="Default Minimum IAC Keep Alive Steps "
020010 Desc =""
020020 Units ="Steps "
020100 Address =0x2815
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F3
020005 Title ="Minimum Keep-Alive BLM "
020010 Desc =""
020020 Units =" "
020100 Address =0x274E
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F4
020005 Title ="Maximum Keep-Alive BLM "
020010 Desc =""
020020 Units =" "
020100 Address =0x274F
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F5
020005 Title ="A/C Clutch Disable %TPS Threshold "
020010 Desc =""
020100 Address =0x2669
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F6
020005 Title ="CAT Overtemp Threshold (Low Baro) "
020010 Desc =""
020100 Address =0x12929
020200 Equation =3.000000 * X + 300.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x64F7
020005 Title ="CAT Overtemp Threshold (Mid Baro) "
020010 Desc =""
020100 Address =0x1292B
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6521
020005 Title ="CAT Overtemp Threshold (High Baro) "
020010 Desc =""
020100 Address =0x1292D
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6522
020005 Title ="CAT Overtemp Baro Threshold 1 "
020010 Desc =""
020100 Address =0x1292A
020200 Equation =0.625000 * X + 24.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6523
020005 Title ="CAT Overtemp Baro Threshold 2 "
020010 Desc =""
020100 Address =0x1292C
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6524
020005 Title ="CAT Overtemp AFR "
020010 Desc =""
020020 Units ="AFR "
020100 Address =0x12931
020200 Equation =0.100000 * X + 0.000000,TH|0|0|0|0|
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6525
020005 Title ="Minimum Integrator Value "
020010 Desc =""
020020 Units =" "
020100 Address =0x26ED
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6526
020005 Title ="Maximum Integrator Value "
020010 Desc =""
020020 Units =" "
020100 Address =0x26EC
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6527
020005 Title ="Reverse Inhibit Vehicle Speed "
020010 Desc =""
020100 Address =0x26BF
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6528
020005 Title ="Reverse Enable Vehicle Speed "
020010 Desc =""
020100 Address =0x26C0
%%END%%
%%CONSTANT%%
000002 UniqueID =0x6529
020005 Title ="Closed Loop Idle Enable Vehicle Speed "
020010 Desc =""
020100 Address =0x277D
%%END%%
%%FLAG%%
000002 UniqueID =0x652A
030005 Title ="VATS Select (X = Enabled) "
030011 DescSize =0xCDCDCDCD
030010 Desc =""
030100 Address =0x12028
030200 BitNumber =0x3
%%END%%
%%FLAG%%
000002 UniqueID =0x6556
030005 Title ="Traction Control (X = Enabled) "
030010 Desc =""
030200 BitNumber =0x0
%%END%%
%%FLAG%%
000002 UniqueID =0x6557
030005 Title ="C.A.R.S. Select (X = Enabled) "
030010 Desc =""
030100 Address =0x2028
030200 BitNumber =0x2
%%END%%
%%FLAG%%
000002 UniqueID =0x6558
030005 Title ="EGR Diagnostic, Error 32 "
030010 Desc =""
030100 Address =0x207D
030200 BitNumber =0x6
%%END%%
%%FLAG%%
000002 UniqueID =0x6559
030005 Title ="EGR Electrical Failure, Error 27 "
030010 Desc =""
030100 Address =0x207C
%%END%%
%%FLAG%%
000002 UniqueID =0x655A
030005 Title ="CCP Electrical Failure, Error 26 "
030010 Desc =""
030200 BitNumber =0x1
%%END%%
%%FLAG%%
000002 UniqueID =0x655B
030005 Title ="A/C Low Charge Diagnostic, Error 61 "
030010 Desc =""
030100 Address =0x207E
%%END%%
%%FLAG%%
000002 UniqueID =0x655C
030005 Title ="A/C Press Sensor Diagnostic, Error 66 "
030010 Desc =""
030100 Address =0x207F
%%END%%
%%FLAG%%
000002 UniqueID =0x655D
030005 Title ="A/C Press Sensor Diagnostic, Error 67 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x655E
030005 Title ="A/C Relay Diagnostic, Error 68 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6587
030005 Title ="A/C Clutch Diagnostic, Error 69 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6588
030005 Title ="A/C Evap. Temp. Diagnostic, Error 71 "
030010 Desc =""
030100 Address =0x2080
%%END%%
%%FLAG%%
000002 UniqueID =0x6589
030005 Title ="Speed Density Mode (X= Enabled) "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x658A
030005 Title ="Air Pump Diagnostic, Error 29 "
030010 Desc =""
030200 BitNumber =0x7
%%END%%
%%FLAG%%
000002 UniqueID =0x658B
030005 Title ="High MAP Diagnostic, Error 33 "
030010 Desc =""
030100 Address =0x2081
030200 BitNumber =0x4
%%END%%
%%FLAG%%
000002 UniqueID =0x658C
030005 Title ="Vss Signal Diagnostic, Error 97 "
030010 Desc =""
030100 Address =0x2086
%%END%%
%%FLAG%%
000002 UniqueID =0x658D
030005 Title ="Fan 1 Diagnostic, Error 77 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x658E
030005 Title ="Fan 2 Diagnostic, Error 78 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x658F
030005 Title ="Oil Life Diagnostic, Error 95 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65BB
030005 Title ="Oil Level Diagnostic, Error 96 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65BC
030005 Title ="Vehicle Speed Diagnostic, Error 24 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65BD
030005 Title ="Brake Switch Shorted Diag, Error 37 "
030010 Desc =""
030100 Address =0x2082
%%END%%
%%FLAG%%
000002 UniqueID =0x65BE
030005 Title ="Brake Switch Open Diag, Error 38 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65BF
030005 Title ="VATS Diagnostic, Error 46 "
030010 Desc =""
030200 BitNumber =0x5
%%END%%
%%FLAG%%
000002 UniqueID =0x65C0
030005 Title ="MAF System Diagnostic, Error 48 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65C1
030005 Title ="Trans. Temperature High Diag, Error 58 "
030010 Desc =""
030100 Address =0x2083
%%END%%
%%FLAG%%
000002 UniqueID =0x65C2
030005 Title ="Trans. Temperature Low Diag, Error 59 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65EC
030005 Title ="A/C Clutch Relay Diagnostic, Error 70 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65ED
030005 Title ="No Vss Signal Diagnostic, Error 72 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65EE
030005 Title ="Force Motor Current Diag, Error 73 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65EF
030005 Title ="Traction Control Diagnostic, Error 74 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65F0
030005 Title ="Trans System Voltage Diag, Error 75 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65F1
030005 Title ="Trans Fluid Temp. High Diag, Error 79 "
030010 Desc =""
030100 Address =0x2084
%%END%%
%%FLAG%%
000002 UniqueID =0x65F2
030005 Title ="Trans Shift 'B' Diag, Error 81 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65F3
030005 Title ="Trans Shift 'A' Diag, Error 82 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x65F4
030005 Title ="TCC Control Feedback Diag, Error 83 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6620
030005 Title ="3->2 Downshift Feedback Diag, Error 84 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6621
030005 Title ="TCC Stuck On Diagnostic, Error 85 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6622
030005 Title ="TCC Enable Error Diagnostic, Error 90 "
030010 Desc =""
030100 Address =0x2085
%%END%%
%%FLAG%%
000002 UniqueID =0x6623
030005 Title ="Shift Light Diagnostic, Error 91 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6624
030005 Title ="Knock Sensor Diagnostic, Error 43 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6625
030005 Title ="Crank AIR Select (X = Enabled) "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6626
030005 Title ="TCC Release at Low TPS (X=Enabled) "
030010 Desc =""
030100 Address =0x34D9
%%END%%
%%FLAG%%
000002 UniqueID =0x6627
030005 Title ="TCC Release with Rapid TPS Decrease "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6654
030005 Title ="TCC Enable/Disable (X=Enabled) "
030010 Desc =""
030100 Address =0x34DA
%%END%%
%%FLAG%%
000002 UniqueID =0x6655
030005 Title ="Left O2 Sensor Failure, Error 13 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6656
030005 Title ="MAT Sensor Low Failure, Error 23 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6657
030005 Title ="MAT Sensor High Failure, Error 25 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6658
030005 Title ="Left O2 Sensor Lean, Error 44 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x6659
030005 Title ="Left O2 Sensor Rich, Error 45 "
030010 Desc =""
%%END%%
%%FLAG%%
000002 UniqueID =0x665A
030005 Title ="( "
030010 Desc =""
030100 Address =0x10008
%%END%%
%%FLAG%%
000002 UniqueID =0x6685
030005 Title =" "
030010 Desc =""
030100 Address =0x400004
%%END%%
%%FLAG%%
000002 UniqueID =0x6686
030005 Title =" "
030010 Desc =""
030100 Address =0x20001
%%END%%
%%FLAG%%
000002 UniqueID =0x6687
030005 Title ="ƒ "
030010 Desc =""
030100 Address =0x80001
%%END%%
%%FLAG%%
000002 UniqueID =0x6688
030005 Title ="} "
030010 Desc =""
030100 Address =0x20004
%%END%%
%%FLAG%%
000002 UniqueID =0x6689
030005 Title =""
030010 Desc =""
030100 Address =0x40001
%%END%%
%%FLAG%%
000002 UniqueID =0x668A
030005 Title ="€"
030010 Desc =""
030100 Address =0x800002
%%END%%
%%TABLE%%
000002 UniqueID =0x668B
040005 Title ="Main Spark Advance Vs. RPM Vs. MAP "
040011 DescSize =0x0
040010 Desc =""
040100 Address =0x1208A
040200 ZEq =(0.500000 * (X - Y)) + 0.000000,TH|0|0|0|0|,AD|12086|8|0|0|
040230 RangeLow =0.0000
040240 RangeHigh =255.0000
040300 Rows =0xF
040305 Cols =0x10
040320 XUnits ="MAP (Kpa) "
040325 YUnits ="RPM "
040330 ZUnits =""
040350 XLabels =25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100
040352 XLabelType =0x4
040354 XEq =
040360 YLabels =400,600,800,1000,1200,1400,1600,1800,2000,2200,2400,2800,3200,3600,4000
040362 YLabelType =0x4
040364 YEq =
040660 XAxisMin =0.000000
040670 XAxisMax =1000.000000
040760 YAxisMin =0.000000
040770 YAxisMax =1000.000000
%%END%%
%%TABLE%%
000002 UniqueID =0x668C
040005 Title ="Extended Spark Advance Vs. RPM Vs. MAP "
040010 Desc =""
040100 Address =0x1217D
040300 Rows =0x7
040305 Cols =0x10
040330 ZUnits =""
040354 XEq =
040360 YLabels =4000,4500,5000,5500,6000,6500,7000
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66BA
040005 Title ="Closed TPS Spark Advance Vs. RPM "
040010 Desc =""
040100 Address =0x12056
040300 Rows =0xD
040305 Cols =0x1
040320 XUnits ="Deg Spk "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040360 YLabels =0,400,800,1200,1600,2000,2400,2800,3200,3600,4000,4400,4800
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66BB
040005 Title ="Minimum Spark Advance Vs. RPM "
040010 Desc =""
040100 Address =0x12064
040200 ZEq =(0.500000 * (X - Y)) + 0.000000,TH|0|0|0|0|,AD|12063|8|0|0|
040300 Rows =0x11
040305 Cols =0x1
040320 XUnits ="Deg. "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040360 YLabels =0,400,800,1200,1600,2000,2400,2800,3200,3600,4000,4400,4800,5200,5600,6000,6400
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66BC
040005 Title ="Injector Offset Vs. Battery Voltage "
040010 Desc =""
040100 Address =0x129D5
040200 ZEq =(30.517580 * X) + 0.000000,TH|0|0|0|0|
040300 Rows =0x20
040305 Cols =0x1
040320 XUnits ="usec "
040325 YUnits ="VDC "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040360 YLabels =0.0,1.6,3.2,4.8,5.2,5.6,6.0,6.4,6.8,7.2,7.6,8.0,8.4,8.8,9.2,9.6,10.0,10.4,10.8,11.2,11.6,12.0,12.4,12.8,13.2,13.6,14.0,14.4,14.8,16.4,18.0,19.6
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66BD
040005 Title ="Traction Control Spark Retard Vs. RPM "
040010 Desc =""
040100 Address =0x123A1
040200 ZEq =(0.250000 * X) + 0.000000,TH|0|0|0|0|
040300 Rows =0x11
040305 Cols =0x1
040320 XUnits ="Deg Retard "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66BE
040005 Title ="%TPS Threshold For WOT Vs. RPM (Low Cool) "
040010 Desc =""
040100 Address =0x128E7
040200 ZEq =(0.390625 * X) + 0.000000,TH|0|0|0|0|
040300 Rows =0x11
040305 Cols =0x1
040320 XUnits ="%TPS "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66BF
040005 Title ="%TPS Threshold For WOT Vs. RPM (High Cool) "
040010 Desc =""
040100 Address =0x128F8
040300 Rows =0x11
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66C0
040005 Title ="%Change To Fuel/Air Ratio Vs. Cool. Temp. at WOT "
040010 Desc =""
040100 Address =0x12909
040300 Rows =0xF
040305 Cols =0x1
040320 XUnits ="%Change "
040325 YUnits ="Deg C "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040360 YLabels =-40,-28,-16,-4,8,20,32,44,56,68,80,92,104,116,128
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66EE
040005 Title ="%Change To Fuel/Air Ratio Vs. RPM at WOT "
040010 Desc =""
040100 Address =0x12918
040200 ZEq =(0.390625 * X) + -50.000000,TH|0|0|0|0|
040300 Rows =0x11
040305 Cols =0x1
040320 XUnits ="% Change "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040360 YLabels =400,800,1200,1600,2000,2400,2800,3200,3600,4000,4400,4800,5200,5600,6000,6400,6800
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66EF
040005 Title ="Open Loop AFR Vs Coolant Temp. Vs. MAP "
040010 Desc =""
040100 Address =0x12A11
040200 ZEq =(0.100000 * X) + 0.000000,TH|0|0|0|0|
040300 Rows =0xF
040305 Cols =0x11
040330 ZUnits =""
040350 XLabels =20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66F0
040005 Title ="IAC Target RPM Vs. Coolant Temp, (In Drive) "
040010 Desc =""
040100 Address =0x275B
040200 ZEq =(12.500000 * X) + 0.000000,TH|0|0|0|0|
040300 Rows =0xE
040305 Cols =0x1
040320 XUnits ="RPM "
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
000002 UniqueID =0x66F1
040005 Title ="IAC Target RPM Vs. Coolant Temp, (In Park/Neut.) "
040010 Desc =""
040100 Address =0x2769
040300 Rows =0xE
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
040
XDF
1.110000
%%HEADER%%
001006 Desc =""
001010 Author =""
001200 ADSAssoc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units =" "
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units =" "
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units =" "
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units ="% "
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units =" "
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units =" "
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units =" "
%%END%%
%%CONSTANT%%
020010 Desc =""
020020 Units =" "
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%CONSTANT%%
020010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030010 Desc =""
%%END%%
%%FLAG%%
030005 Title ="( "
030010 Desc =""
%%END%%
%%FLAG%%
030005 Title =" "
030010 Desc =""
%%END%%
%%FLAG%%
030005 Title =" "
030010 Desc =""
%%END%%
%%FLAG%%
030005 Title ="ƒ "
030010 Desc =""
%%END%%
%%FLAG%%
030005 Title ="} "
030010 Desc =""
%%END%%
%%FLAG%%
030005 Title =""
030010 Desc =""
%%END%%
%%FLAG%%
030005 Title ="€"
030010 Desc =""
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0xF
040305 Cols =0x10
040330 ZUnits =""
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0x7
040305 Cols =0x10
040330 ZUnits =""
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0xD
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0x11
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0x20
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0x11
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0x11
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0x11
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0xF
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0x11
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0xF
040305 Cols =0x11
040330 ZUnits =""
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0xE
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
%%END%%
%%TABLE%%
040010 Desc =""
040300 Rows =0xE
040305 Cols =0x1
040330 ZUnits =""
040350 XLabels =
040354 XEq =
040364 YEq =
040
