data for 95 s-10 need files
hi , i am looking for xdf and adx files for 1995 s-10 5spd, with 4.3 tbi it also has 16 pin dlc under dash. vcm is located under hood left side, also say obd1 on radiator support, thanks for any help. I like to see the sensor data, i trying to use tunerpro vf-5
There's about 225 files here:
http://www.eagle-mark.com/Forums/
Oh.. under the hood, I think your right. I just saw the 95 TBI and thought it would be the 427 type.robertisaar wrote:sounds like the blackbox VCM.... that's an early OBD2 PCM.
So the black box is no good with TunerPro to see data anyway?
Cool! didn't know that... links to useable cables please!
any REAL ELM327 cable should work, though a lot of companies have more or less attempted to make their own IC, since ELM charges a rather high price for theirs. some work well, some don't.
http://tunerpro.net/downloadPlugins.html
so will i still need a xdf and also ads with this elm327 to use tunerpro rt and yes it is vcm black box under the hood, but what throws me it say obd1 complaint on rad support. I also found data stream 192.ds file for this s-10, i do believe this is also a flash prom puter from gm. Also the pin location in the dlc are 4,5,6, 9, 16robertisaar wrote:any REAL ELM327 cable should work, though a lot of companies have more or less attempted to make their own IC, since ELM charges a rather high price for theirs. some work well, some don't.
bumpjlsug wrote:so will i still need a xdf and also ads with this elm327 to use tunerpro rt and yes it is vcm black box under the hood, but what throws me it say obd1 complaint on rad support. I also found data stream 192.ds file for this s-10, i do believe this is also a flash prom puter from gm. Also the pin location in the dlc are 4,5,6, 9, 16robertisaar wrote:any REAL ELM327 cable should work, though a lot of companies have more or less attempted to make their own IC, since ELM charges a rather high price for theirs. some work well, some don't.
