TunerPro v5 won't start
kj16v
Post by kj16v »
Hi. I've been tuning cars regularly for several years using TunerPro v4 on my old laptop running Windows XP SP2.
Today I installed TP v5; my laptop isn't connected to the 'net, so I downloaded the P setup program on to a USB pen, copied it onto my laptop and then ran it as normal.
When I try to open TP v5, instead of opening, I get this message:
"Theprocedure enty point DecodePointer could not be located in the dynamic link library KERNAL32.DLL"
TPv4 still works as normal.
Anyone else come across this? How do I get TP v5 running?
Cheers
http://www.tunerpro.net/features.htm
Bottom of the page. Requires SP3.
kj16v
Post by kj16v »
Brilliant, problem solved!
kj16v
Post by kj16v »
...Well, nearly solved!
I had a quick play with v5 using the Fiat Coupe 16V Turbo xdf I wrote (it's posted up on the Tunerpro website). and it's garbled the breakpoints values in two of the tables. The conversion equation is simply 187500/X.
Is this a bug, or is there a simple fix for this?
BTW. The address hit tracing is just car-nerd heaven :D
You would need to send me the XDF and bin via email, and describe the problem for me to look for.
Until I find the problem, my stance is that it's a bug in the XDF. =)
kj16v
Post by kj16v »
emailed. Cheers
