Latest Iteration of TunerPro crashes when comparing
86ttopbird
Post by 86ttopbird »
This latest build of Tunerpro will always crash when trying to compare bins. Yes they are the same type as in read with the same xdf. It also happens when you hit "select all" when trying to copy a table over. I had to revert to an older version of TP V5 that I had laying around so I could finish the new bin im working on. Since it likes to crash right in the middle of having the bin open, I have had to start all over with both my xdf and my bin files for fear that errors were introduced due to the program crashing. Mangus, I have emailed you my event viewer logs to try and track down what is causing it. This problem just recently surfaced with the new build so something is not right. The older version runs just fine and does not have any of these issues.
Email me the files and steps necessary to reproduce the issue.
