Buttons in ADX
rob
Buttons in ADX
Post by rob »
I would really like to have Buttons in the adx part of tuner pro to interact with the ECU. In the Marelli P8 ECU for example i could perform various tests by sending a byte with the MSB set (anything above 0x80). Therefore a Button Feature would be nice. I think of handling it like a gauge in the dash and when pressed performing a task with an ID as it is already done automatically.
Interesting idea. In the meantime, I will soon be adding the ability to trigger commands manually via the "Data Acquisition Send Command" toolbar. Look for that soon.
I like the idea of being able to add buttons to the dashboard.
i wondered when that little toolbar was going to get put to use.....
maybe i'll be able to get some mode 4 stuff tested.
rob
Post by rob »
Glad to hear it. I've been digging into OBD Diagnostics for the last couple of month, even bought some hardware and it occured to me that it would be a nice feature for TP to have logging capabilities with obd too quasi as a successor to ALDL.
I know that there are some problems (5 Baud init, Packet structure, Keep alive packets,...) which are difficult to implement in software and i am not certain thats what TP was intended to be, but maybe with a small box that do the low level work. After my finishing Master Thesis (next April) i will build such a box with an AVR controller.
hnracing
Post by hnracing »
This would be a very useful funtion for the Marelli ECU, 15M, 16M & P8.
I would like to have it as a dialog box or button.
For two different funtions.
Troubleshooting:
Be able to send different error/status questions and translate the answers.
Perform test:
Be able to perform different testfuntions.
/Henrik
