TunerPro RT Logging
TunerPro RT Logging
I just got my ALDL cable and downloaded TunerPro RT. I have the cable hooked up to my 90 buick 3.3L car. The program says I am connected, I created a log file and click record and it says its recording. I click stop and it asks for some notes and I click ok. I can press play and the very bottom of the screen says play and clicks off some numbers. However I don't see any data on the screen? How do I see the data? I'd actaully just like to watch it as I collect it. I think I have the right .ads file. How do I get the data to show up on the screen?
Also my packet error count is always climbing. I'm using the 6d.ads file from the tunerpro website.
"Newbie"
Chris
"Newbie"
Chris
Okay, so I played around with it a little more and now can see the different sensors. I can connect to the ECU and start logging, but my values never change. I don't find an exact .ads file for my vehicle. 1990 buick century 3.3L V6. I tried a couple that were close. When I use 6D.ads, I get the packet error count climbing. When I use 1227148TBuick.ads, the error count doesn't go up, but I still don't see any values changing.
Help please.
Help please.
Thanks Robert for sending the file so quickly.
When I tried it this morning it worked, however it would only show real time data with the ign on and the engine NOT running. As soon as I start the engine, the data stops coming. I have tried connecting with the engine running and the program will not connect. It works fine with the engine off though. Any ideas?
Yes, if I remember right, packet counter started climbing.
I seem to be going backwards here. this morning when I tried your new .ads file, I could at least connect to the ecm and see the data with the enigne not running, but ign on. I could see the tps change voltage. Now I can't even get it to connect to see that anymore.
I wonder if my ECM is messed up. The whole reason I am trying to get this software working is to trouble shoot a problem with an ill running car. But the strange thing is, there's time when it runs like top and no check engine light. I let it run that way for 30 minutes. Can't get it to mess up. Then I shut if off, let it sit for 15 miniutes and then start it and it runs like crap, check engine light on, etc. It's like some one flipped a switch. So maybe the ECM is taking a crap.
I may try that. Here's another piece of the puzzle. I finally got it to connect by disconnecting the battery and reconnecting. The difference I noticed was with the ign on all the idiot lights were on. Before, the high coolant temp was not on. With all the idiot lights on, the program connected and I could see all the data coming through. I could even start the car. It ran for about 45 seconds with data flowing, then the check engine light came on and the data stopped. Then when I shut it off and turned the car back to ign on, the coolant light wasn't on and it would not cconnect. If I cycle the ignition on and off I can sometimes see the high coolant light flicker, but it doesn't want to stay on. Must be gremmlins?
Well, I replaced the ECM and all seems to be good now. I'm glad that I didn't throw a bunch of money and parts at the car trying to guess at whats wrong. I bought the $60 ALDL cable and downloaded this tunerpro program and was able to partly diagnose the problem.
A special thanks for Robertisaar. Thanks for the .ads file and thanks for getting it to quickly to me. I'm sure it will get used again on this car at some time...
Later
Later
