I have read a bin file from 413 ECU to tune it, but it came out in 32k size, when I opened it with tunerpro it gave me 0 values all over the tables, I did this many times and it just gave me the same file size, so I loaded the original 413 .bin that I downloaded from tunerpro into Ostrich2, it was 64k file size, and worked fine with the Ostrich2, I managed to tune the car with some spark advance in weak areas and the car was great, I had the problem when I tried to burn the tuned .bin file into the chip, I used 27C512, every time I tried to burn the .bin the Moates flash&burn gives me that am using the wrong size, I noticed that start address in hex for chip starts as 000001, so I set it to 000000 and burned successfully, but when I placed the chip on the ECU, the engine didn't start!! I think am lost here, anyone can help?
Also I tried to raise the rev-limit for that engine , but it didn't work, I tried lower values, and higher values, but no use, what value I can set so it can rev to 7000 or 7200 RPM
your help is highly appreciated
