editing tables
Lloyd Johnson
editing tables
Post by Lloyd Johnson »
I finally got the ecm to read the chips I burned and you right it was not the G-1 adapter I think it was the way my drivers were set up in my computer. Problems I am having now is I can make changes to the constants and flags and save and it works. When I make changes to the tables and hit save the table closes and when I reopen it the changes are gone. If I double click on one box and the number disappears then insert a number and hit save it will save that number. I read a help file on this that was posted in april sounds like the same problem but I didnt see afix for it. Other problem I havent been able to get the datalogging to work.
This system sure looks cool if I can get everything to work.
Thanks Lloyd
383 edelbrock e-tec heads, roller cam, 10-1 compression,
make sure you're running the latest build.
Lloyd Johnson
updates
I go under help and check for updates it says there is a update available I try to download it and it cancels with a error #5 so it wont download it. How do I fix that.
no idea. probably a problem with your browser.
go directly to the web site and download it.
