Table scales starting at a given value
yoda69
Post by yoda69 »
This one maybe specific only to Aussie MAF tables but here goes.
There are 8 MAF Tables, each with 9 Values, as far as the labels go, the last label in table 1 is the first in Table 2, etc, and each label is incremented by 128 Hz. Where the problem arises, is that the starting value of table 1 is based of a 16bit number, so the actual row labels can be different for different MAF's. This can cause problems when trying to fit a different MAF, as the minimum Hz value maybe different for the same flow.
What I basically need is a way of given a starting value in the bin, use this to populate the tables with each value increased by a given amount (in this case 128 Hz).
I looked at the 4 options of of populating labels, and none of them appear to work for this scenario.
All this actually came about by datalogging and using the Ostrich's capability to data trace, and noticed they didn't line up as anticipated.
yoda69
ipejasinovic
Post by ipejasinovic »
+1
Support for this and similar (complex) interactions will come online in future revisions. Bosch axis definitions (Motronic - Porsche, Merc, etc) also require similar functionality.
It's not an easy problem to solve generically, but we'll get there.
yoda69
Post by yoda69 »
Mangus,
Thanks for that, we all appreciate the work you put into TP, the more detailed requests we can put in the better chance we have of them being implemented in the future.
yoda69
