How do I get data hit tracing to work?
Justin517
Post by Justin517 »
I have an Ostrich 2.0 and am using Tunerpro RT and I was under the impression that I can do data tracing while running.
Do I have to set up the ALDL (which is way over my head)? I didnt think I had to, I thought ostrich would show automatically what info was being used?
my car is a 1989 BMW 535i with a 179 DME, not the more popular and more developed 173.
any help would be greatly appreciated.
revlimit
Post by revlimit »
When you are looking at the maps you klick on the sign that is shaped like an A letter in the top, then you will see the yellow curser tracer on the map if the ECU is using that particular map. Very easy.
bmwconnect
Post by bmwconnect »
I also like to use cam studio(open source) to record tracing when tuning cars alone it's very handy
FastButBlind
Post by FastButBlind »
Finally managed to work on the ostrich2 now, but I do have a problem with tracing, whenever I click on A button to trace, it give me ERROR in the status bar(bottom bar) of the window am trying to trace! what could i be missed here!?
I followed all the instructions of installing the ostrich2, but am lost here
I tried it on my cars, with 405ECU and 173ECU
Make sure you're using the latest firmware version for your Ostrich.
FastButBlind
thanks Mangus
I did the firmware update, although it was the latest one on my ostrich2, but now I can trace it, maybe there were errors and cleared with the update
