OK guys I am making real headway.
I was able to read my chip and make a simple change to the bin.
I added 200 rpm to idle when A/C is on and created a new bin.
I have ordered some chips from Moates they are the of the 512 size.
I believe this means I need to use the Bin stacker in Tuner Pro.
The Bin stacker has three parameters,Bin size, Chip Size and Block size.
I believe the bin size is 16K, the chip size will be 512K but what should I set the block size at?
Bin Stacker and Block Size
