1227749 and autoprom
SyTyArchives
Post by SyTyArchives »
I could have swarn I hit submit on this, so if you removed it I appologize for sending it again...
Just want to add a formal request to getting datalogging and emulating working at the same time for the syclone/typhoon crowd, I've got one in the post and really looking forward to this working in the new version.
Chatting a bit with Paul ( I guess you guys live near one-another) and he mentioned that it was simply a software thing, so I just wanted to be vocal about it so you can see theres some interest in getting this working.
Yes, Paul's right, its really just a software thing. Unfortunately its not a simple software thing. I will address it, though, in the 4.0 series.
The problem is two-fold:
1) The SyTy bins spew tons of unsolicited data to the ALDL stream. I need to add a connection provision in TunerPro to spam the ECM with the silence ( mode 8 ) command before attempting to connet.
2) Once the above is implemented and working in non-AutoProm mode, I then need to implement the new AutoProm ALDL mode passthrough in software.
#1 is the tough one. In any case, I have the plan worked out, its just a matter of implementing it. It requires a bunch of architectural changes under the covers, which is why I've been putting it off.
Thanks for the suggestion. I'm thinking about you SyTy guys, worry not!
Mark
