APU1 w/ LC-1 Wide Band
Rally Smith
Post by Rally Smith »
I had everything hooked up with the factory Narrow Band Sensor and made some changes. I now have a Innovation LC-1 w/ W/B Sensor. I have it wired up with the analog output going into the APU1 analog input. How do I send the w/b info through the APU1 to the laptop. I need to know where to go in the Tuner Pro RT program to make the W/B sensor info usable with the program.
RS
Re: APU1 w/ LC-1 Wide Band
Rally Smith wrote:I had everything hooked up with the factory Narrow Band Sensor and made some changes. I now have a Innovation LC-1 w/ W/B Sensor. I have it wired up with the analog output going into the APU1 analog input. How do I send the w/b info through the APU1 to the laptop. I need to know where to go in the Tuner Pro RT program to make the W/B sensor info usable with the program.
RS
The APU1 A/D packet is appended to the end of the ECM packet. The inlucded 6E definition shows how to set it up. (channel one is byte 67, 2 is 69, and 3 is 71).
