Hi guys,
I have one question and will appreciate your help!
I have a Renault 19 1,7 MPI turbo modified by me.Using e-manage piggyback and the result is 210+ hp on the flywheel.
Now I want to remap my original ECU with 337cc injectors.
Can I import the table using 2 bar MAP from Renault 21 turbo or I must use mine and only adjust the fuel?(2 bars is 2 times larger than mine and may be the ECU can not work with bigger table )
Also how to understand the maximum RPM values?
Thanks in advance
