ostrich and datamaster datalogging, how to? 93 lt1 vette SC
dizwiz24
Post by dizwiz24 »
I recently installed a procharger on my mod'd 93 LT1 vette. Im having some issues with knock retard. Not sure if real, or fake.
Either way, I need to do some hard core datalogging. My Auto X-Ray frame scanner (that plugs into the ALDL) doesnt have the resolution (ie. it doesnt capture every frame).
I have Datamaster, and have used it before - w/ cable plugged into the ALDL.
Unfortunately, I have connection errors now.
Im not sure if its because I am using an Ostrich or what.
Anyways, I need to use this to get a better 'handle' on knock counts, knock retard, etc.
Does anyone know of anyway I can do some quality datalogging with ostrich in place?
If it is impossible, does anyone have a procedure I can use to find out and correct this. Any help is, as always, appreciated.
Ostrich is an emulation device. It will not hook up to the ALDL stream.
honken
Post by honken »
You need to find the comport datamaster use.
The ostrich use one port(ex2)and the aldl program use another (ex3).
Change port settings in datamaster to find it.
