selecting multiple points on a graph.
drumer919
Post by drumer919 »
Is the a way when looking at a 3D graph to select multiple points multiple times with the mouse? Like a click and highlight some points with the box, then hold a button and select more points with a box again. Is that possible?
Dan- ASE certified-A1, A4, A5, A8
95 S10 ecsb, 350, 9.5:1, ported Vortec heads, Crane(.484/.512 272/284 112LSA), OBD2 L31 intake, Hooker LT's, 2.5"ORY, Flowmaster 40, 4L60E, 8.8 posi w/ 3.73's, WBO2, '7427 PCM running in PFI mode, $OD.
dfddfd2
Post by dfddfd2 »
Yes. Hold the ctrl key down while selecting the points you want to move.
Drag and highlight (selection box) works too.
drumer919
Post by drumer919 »
When I select multiple points with the box then want to use a box again to select more points is that possible, I know that after I use the box I can hold control to select individual points but if I try to click with the mouse it just moves the graph.
JP86SS
Post by JP86SS »
Can't use the box 2 times. Individual points can be added with Cntl button.
Holding the mouse down will move the graph like you saw.
Cntl works in the editor window too for selecting multiple cells.
JP86SS wrote:Cntl works in the editor window too for selecting multiple cells.
Shift does, not control. I'll eventually add scatter selection to the grid control as well.
