Problems writing bin file
SPOOLD U
Post by SPOOLD U »
I have a 29F040B chip from Moates that I am trying to burn a 512k image to. I have stacked 16 32k images on it, to fill it up. I am using the default ranges for chip size and buffer size. Every time I try to write the bin with tunerpro I get an error at about 4000ish during the write and it returns an error - "ERROR: PROM I/O returned failure". I can't figure out what I'm doing wrong. Any suggestions on what to check? I have never had issues with 128 or 256 chips before.
SPOOLD U
Post by SPOOLD U »
anyone have suggestions? I'm stumped. Is there a way I can attach the file for someone else to try?
dfddfd2
Post by dfddfd2 »
Looks like you might need to changed the Buffer Addressing End Address to 07FFFF. The default comes up as 007FFF for the 29F040B.
SPOOLD U
Post by SPOOLD U »
both my buffer address and chip address are set to 000000-07FFFF.
Perhaps try a different USB cable (noise issue), or try running it through a USB hub with an external power adapter (might be a power issue).
Try erasing the chip, then verify that it has been erased. Then do your write.
