table editor bug
TheGreatJ
table editor bug
Post by TheGreatJ »
A little glitch I found in v3.09: (using Win98SE on my laptop)
When using the table editor toolbox, you cannot fill a row/column/table with 0's. You also cannot work around this by multiplying by 0. I've been filling with 1's and then offsetting by -1. :D
Hmm. I'll look into this and fix it for ya'. Thanks. ;-)
TheGreatJ
Post by TheGreatJ »
Found another one, this time by accident.
I went to edit a bin and accidentally clicked on a stacked bin which had the first slot empty. I have default .ecu loading enabled, and it obviously couldn't find the default .ecu (as the mask addy was empty.) It gave me an error window, which I closed, and then it pulled up the view lists, all blank. No surprise there, but when I opened the .bin I was originally aiming for, it still kept the lists blank. Closing and reopening the lists did no good....had to restart TunerPro.
Not a major glitch, but something I thought you might want to know about. If it was mine I'd want to fix it, but then again I'm a perfectionist.
Have a good one. :mrgreen:
Thanks!
