Novice questions
86iroctpi
Novice questions
Post by 86iroctpi »
I am trying to program a chip for a 7747 ecm. I am not sure about a few things. I have the G2 adapter from moates to utilize the at29c256 chip.
1. I am using the 747-mine.ecu file (this is the only .ecu file I could find for this ecm). Is this correct file?
2. In bin stacker, should I set the bin, chip, and block sizes all to 4k?
3. I need to set the start adress in hex 007000 for the chip, correct?
4. Should I set the buffer adress at 007000 also?
That is all for now.
Thanks in advance,
Jared
If you stack, set the chip size to 32k, block size to 32k, and bin size to 4k. If stacked, when burning, start at offset 0 for both the buffer and chip.
If you dont want to stack, burn the raw 4k bin to the chip starting at $7000.
M
Greenbuggy
Post by Greenbuggy »
'51 Ford F-6 Dually Dumptruck/'72 Cheyenne20/'59 VW Chassied Buggy/'85 Honda Prelude/'91 Nissan Maxima
Check out my site at Http://www.speedyoldtruck.com
Always looking for Caddy N* information, working on a tunable OBD1 ECU.
