How to setup map axis for re-use ?
audichap
Post by audichap »
I've had to create a number of XDFs for old Motronic systems here. I've not yet finished my PHP project that will automate the creation of the XDF by parsing the bin files...
So - I'm stuck with handcoding each map for now... manualy typing in the axis values for numerous maps - which are often the same. Is there a way I can create a structure in the form of an axis description that I can just call up and apply to new maps within the XDF ?
I keep thinking its what Category A and B are for - but I'm not getting it.
dfddfd2
Post by dfddfd2 »
You can cut and paste from a spread sheet or text file. I created a spread sheet that has all of my axis labels defined.
Cheers,
Dave
This is something I'm thinking about for v5, as well as the ability to define common conversion equations. Both would keep you from having to re-type everything each time.
Ultimately I want TunerPro to support the strange Bosch/Motronic axis calculations.
