No Sensor or Bit Data Displayed
VetNutJim
Post by VetNutJim »
TunerPro RT Version 3.07
TunerPro RT Datastream Definition - 10/7/03
OS: Windows 98
Connected using the 127730 Datastream Definition File.
Connection seemed ok. Could see the TPS Voltage I selected displayed on the Monitor.
Saved data to file.
Got NO Sensor Data or Bit Data displayed during the session or afterwards during playback.
TPS Voltage was displayed in the monitor during playback but still no Sensor or Bit Data.
Any idea what I'm doing wrong?
VetNutJim
Post by VetNutJim »
Well, this is about the most UNRESPONSIVE bunch I've ever encountered.
Since it's OBVIOUS NO ONE KNOWS the answer to this and since I have found out on my own, I'LL post the answer for everybody else here.
This program REQUIRES a copy of "RICHED20.DLL" .
This file is NOT installed when you install TunerPro (can this be patched?)
Download the file form this site and UNZIP it to YOUR TunerPro installed directory.
If you don't remember where the program was installed, do a file search for 'TunerPro.Exe'.
Extrach the RichEd20.DLL file to the directory in which you find TunerPro.Exe.
That's it. You don't have to register the DLL on your computer or anything.
Afterwards, your Sensor Data and Bit Data in the ALDL section will work properly.
Is ANYBody Out There?????
Looks like you found your answer
