newbie questions
atspeedracing
newbie questions
Post by atspeedracing »
hi
i have just been looking through the tuner pro software... findout out what button does what, and what the software has to offer.
i have found a nice 2d and 3d table/graph for spark, and worked out how to adjust it.. but i cant seem to find one for fuel injector duty cycle???
is there one?
all i can seem to find is single column tables for MAF.
ideally i would like to see the same table for the fueling as i would the ignition.. like on most aftermarket ecu mapping software (emerald, dta, motec etc)
does this system only work with MAF, or can it be set up to work with MAP or TPS sensors?
we are looking into using the ostrich emulator.. anyone had any experience with these? what is recomended? we are based in the UK.
majority of the cars we will be doing are citroen/peugoet (bosch/magnetti marelli ecus) and probably some vw/audi/seat too.
thanks
TunerPro will work with a variety of ecu's, it all depends on whether you can find (or make :) ) a xdf for them. If you look on the definition download page you will see a quite a variation available on there are many more out there that people have developed.
