V5
Post by Six_Shooter »
After your last couple of posts, I'm not so sure it's a Tuner Pro problem.
Try this:
After saving the modified ADX, close TP RT and re-open, see if the changes took effect. It may be something in your system (laptop) that's getting hit hard (RAM) and is unable to update as quickly as it should.
Can you try another laptop/computer?
turbodave
Post by turbodave »
Six_Shooter wrote:After your last couple of posts, I'm not so sure it's a Tuner Pro problem.
Try this:
Tried that, didn't help. Here's something that worked a few minutes ago.
I had to create a desktop shortcut, and right click the shortcut and select "run as adminiistrator", in order to be able to make such changes.
I have to do that each and everytime I open the program. Unlike a couple other programs I have had to do this step only once.
Odd indeed.
Now, If I could just get data acquired.
turbodave wrote:Any idea on the data post? I can live with the gauge thing, but I doesn't help much to not be able to acquire data.
I welcome you to continue using V4.
turbodave
Post by turbodave »
OK, thanks for the advice. I was really hoping to get this to work friendly with the Translator Pro.
turbodave wrote:OK, thanks for the advice. I was really hoping to get this to work friendly with the Translator Pro.
It will/should/does. Try contacting Bob; he's got a V5 build and claims to have it working quite well.
turbodave
Post by turbodave »
Bob got me going.
turbodave wrote:Bob got me going.
Solution being?
turbodave
Post by turbodave »
Solution being?
I had imported an ads file from my 4.14 folder, and had V5 convert it to an adx file. That apparently didn't work properly.
He provided me with an adx file he had that works.
Cleared up all the problems I was having.
JP86SS
Post by JP86SS »
Not so sucky!
Not saving when making casual changes to the dash is a good thing.
The setup of the dashboard always comes back after playing around.
I like it that way.
If I find its better a different way, I edit and save it.
I'll be adding a prompt to save the ADX if you've changed the Dash. This satisfies Dave (possibly), and those who would rather not apply their changes permanently.
The only thing I would like added to the whole dash thing is a way to export and import just a single complete dash layout.
It takes a lot of time to input everything to create the same dash you have in another ADX, when an export and import feature would be the "bees knees". :D
Six_Shooter wrote:The only thing I would like added to the whole dash thing is a way to export and import just a single complete dash layout.
oh, i know ALL about that.... i've made at least 10 full featured ADX files, all of them with a different dash....
though, certain ones do necessitate a different dash. a 86 S10 and a 95 vette ZR1 should look different.
I disagree about the should look different part....
I find that no matter what mask I'm tuning, there are certain parameters that I seem to watch, more than others.
It would also be easier to edit the dashes for any new or additional gauges having a set base of gauges already there. :)
