Hello....I am New Here!  Trying to get started on reading and editing my ECU file.   I have an 04 VW r32.  (its a 3.2 vr6) with a VW Bosch Motronic ME7 ecu.
What cables, editors, would i need.  What would the correct steps to read and mod the bin file be.
Thanks for your help.
						vw motronic me7
Im fairly new to this, but this is where I got started:
*Introduction to ECU Programming*
http://www.sciroccovw.com/2009/08/intro ... ogramming/
*Mike Delaney's ECU Basics you should know*
http://www.sciroccovw.com/2009/08/mike- ... ould-know/
Give both of them a read, they offer suggestions to softwares and hardwares to use.Also check out the TunerPro Whitepapers and Tutorials...
lol....thanks for those two links.
So i found out that (a) I need NefMoto ECU Flashing Software http://nefariousmotorsports.com/forum/i ... itle,.html to download and flash the ecu with new files. The questions is how do i know witch memory layout do I use for the flashing?
Then (b) to edit the map I will use TunerPro. But TunerPro will need a definition file (.XDF) for the ECU file. How do i make or find that definition file?
And last (c) whats the deal with the checksums?
Thanks again
Thanks again
NefMOto looks pretty neat!Can't help you with the memory layout..I'm currently trying to learn how to make .xdf's myself but I hit a brick wall.I put a post up here but no response.I'm trying to .xdf a '09 VW 1.4TSI Twincharger ECU File.Checksums are used to check the accuracy of data after it's reached it's destination I think..to ensure data was xfered correctly and not corrupted
