brust knock retard vs knock retard help
89 IROC CONV
hello, can some explain the difference in brust knock retard and knock retard. and what needs to be done to disable them in $42. i see no way to tell which is which when data loging .im trying to tune a new mild sbc . im geting knocks in park and the engine has not been over 3000 rpm. runs ok in open loop which is a very short time. will not get over 20 mph in closed loop graps out. i took no short cuts on the motor the bottom end is all eagle and blanced from eagle. i dont hear any knocks motor has roller timing chain and comp cams gold roller rockers
mark m
89 IROC CONV
