I found a 4 Cyl TBI setup being driven by the 7730 computer.
I have been fighting the $8D code with various success and not.
I have been told, because the way the $8D code is setup, I will get (and probably have) inconsistent fueling.
Hence, I am looking for the $3E code for the 7730.  Can anyone help?
I have a bin for the 4 CYL TBI on the 7730, just no mask.
Thanks!
							Looking for a $3E Broadcast code?
Trying to drive a 4 barrell Holley on a BBC... help!?!?
						Thanks for the reply.
Can th 165 drive 4 injectors and is it a TBI computer?
I am still trying to learn.
I have found the 7730 code in $8D to be fairly straightforward after a LOT of reading. So now I know where to go, to correct issues. Additionally, I am setup well for the P4 chip, and would hate to invest in a another setup. But, if this WORKS, then I am for it.
Also, I like the 8192 baud connection, datalogging, and what I presume is the speed of the computer. This allows the computer to make quicker adjustments to the fuel and timing in closed loop correct.
So far, I have been told I should get the 7747 computer (a little slower) and create driver board to drive the four injectors. I don't know where to get a driver board.
Ideally, I am looking for the best of all worlds solution.
Thanks!
Thanks!
						REALLY???
So there are hacks and known ways for this to drive 4 TBI injectors? WithOUT P&H output?
In other words, there are people running the 165 in a TBI application?
The issue that was presented to me regarding the 7730 is because the 7730 fires on two revolutions on the injector driver. Therefore, I get inconsistent fueling.
So my question is, this is not the case with the 165?
That would be SO kewl!
Thanks.
Thanks.
						That's what I was hoping for.Mangus wrote: I had thought that there were 8192 TBI ECMs out there. Is that not the case?
If not, I will look at a 7747 because it is TBI based. I guess I need to make (or buy) the injector drivers for it.
Apparently, the 165 is also MAF based, correct? I want to stay with the cheaper speed density.
Thanks again!
