V5 Beta Bug List
hackish
V5 Beta Bug List
Post by hackish »
I'll start listing the bugs I find here. I have a weird talent for finding bugs.
Build is 5.00.4532.00
OS is Vista x64
Add a new item (table type) to your XDF
Click OK, then Close (saving a new blank table)
Double click on the table in the XDF Item Tree.
Now, right click on the New Table item
Tuner RT crashes
-Michael
hackish
Post by hackish »
Bug #2
Open a table in the XDF Item Tree so it shows the data
Now select it again in the XDF Item Tree and edit the XDF Item
Make a change to the way the item should be displayed. In my case I adjusted the Address step for a pure internal axis.
Click Apply, then Close
The open item does not update to update the changes.
Close and re-open the table and it will display correctly.
-Michael
hackish
Item conversion does not like DIV0
Post by hackish »
Bug #3
In a table for AFR Override I've defined the AFR as 14.7*128/X so 0x80 is 14.7 and it goes richer or leaner from there. Unfortunately if you have a value of 0 which in my case just disables any override it displays the value as 1.$ instead of something like 'inf'. I'm sure this is being caused by the fact the equation is encountering a divide by 0.
-Michael
hackish wrote:Bug #2
-Michael
That's not a bug, that's just not implemented. It's on the list.
Re: Item conversion does not like DIV0
hackish wrote:Bug #3
-Michael
Correct.
Re: V5 Beta Bug List
hackish wrote:I'll start listing the bugs I find here. I have a weird talent for finding bugs.
OS is Vista x64
Tuner RT crashes
-Michael
Where do you right-click? I've double clicked the new table in the tree (opens the table editor, in which there are no cells), and right clicked all over the table editor and the item in the item tree. No crash.
That said, I'm running a much newer build than is available publicly, so perhaps this is inadvertantly fixed.
hackish
Post by hackish »
You right click the item on the XDF list. I was doing this to go in and edit the table again.
I'll email any more bug reports to you directly.
-Michael
