Regarding 318i/is Bin Files & Defs
				BavarianMotorWorks
All posted software for the e36 318i/is models can be used with any 318i/is ECU from 92-95. I'm unsure of how to find the checksum value for these software's however you will see a check engine light but it will have no effect on your tuning
wide open fuel for softwares start's at 4000rpm, me & revlimit are working to figure out the full WOT maping for these softwares. It's proving to be difficult ... stay tuned!
				BavarianMotorWorks
Because these cars have Throttle sensor potentiometer istead of switch it may be that WOT fuel map is the high part throttle map. This can be figured out with ostrich2 using address watch, you watch the high part throttle map and see if the tracing is still there under high RPM and WOT, if the trace is still there than that is your WOT map.
				BavarianMotorWorks
				BavarianMotorWorks
				BavarianMotorWorks
				BavarianMotorWorks
Checksum
Having trouble calculating checksum for these files. Anybody educated in this matter?
