Please point me in the right direction
Rally Smith
O.k I've been reading like crazy for the last several months. I have an Auto Prom setup for my 95 GMC K1500 5.7 automatic. I can get the auto prom and the ALDL connections on line. I have been trying a bunch of the 0D mask files in all sorts of combination. I'm frustrated beyond belief. If someone would be so gracious to send me a link for the combination's to use in order to data log my truck I would be so very grateful. I can data log with what I have but I have no information coming out of it. I pull up the Dash view and it doesn't read anything. I'm guessing that is due to the fact the wrong definition file is being used...... I'm about ready to just say screw it and start shooting! Not really but you get the idea. If someone could just throw me a freaking bone here I would be eternally in your debt.
Thanks in advance.....I hope.
Rick
Rick
Rally Smith
Rally Smith
Not the same setup, but on my Old GMC Safari van, I couldn't connect by connecting at the ALDL plug, but I followed the wiring from the ECU and found that there was another plug between the ECU and the ALDL connection. I made up a separate plug and used the connection closer to the ECU and all was good. Never did trace the rest of the wire to see what was wrong. Might be worth a shot to check your wiring to the ecu.Rally Smith wrote:Anybody have any other ideas?
Rally Smith
Rally Smith
Rally Smith
For the autoprom settings.
http://www.moates.net/documentation.php ... tion_id=14
Are you reading with scannerpro or tunerpro????
The ve table showing blm when you logging .
The idle ve works at lowe settings on tps.speed(look on your chip settings).
When you drive its Main Fuel Table Off Idle.
Rally Smith
Rally Smith
Rally Smith
you listed both bjym and bjyb twice and i didn't see anything for aixz, but here is the rest:
Broadcast Code: BHDF
Model Year: 1994
Release Date: 05/18/93
EPROM Part Number: 16194631
ECM Part Number: 16196395
PROM ID: 4632
SCAN ID: 4705
Platform Codes: C2,C3,G3,K2,K3
Engine RPO Codes: L19
Engine Displacement (L): 7.4
Transmission RPO Codes: MT1
Transmission Type: MAN
Gear Ratio RPO Codes:
Emmission RPO Codes:
Emissions Catagory: *
GVWR Ratings: 9E6,C6U,C6Y
Broadcast Code: BHRJ
Model Year: 1994
EPROM Part Number: 16195894
PROM ID: 5896
SCAN ID: 5925
Platform Codes: S1,T1
Engine RPO Codes: L35
Engine Displacement (L): 4.3
Gear Ratio RPO Codes: GU4,GU6
GVWR Ratings: CTF
Broadcast Code: BNBH
Model Year: 1995
Release Date: 08/09/94
EPROM Part Number: 16212134
ECM Part Number: 16197427
PROM ID: 2136
SCAN ID: 2125
Platform Codes: M1
Emmission RPO Codes: -NM8
GVWR Ratings: VD1
Broadcast Code: BJYB
Model Year: 1995
Release Date: 12/22/93
EPROM Part Number: 16200074
PROM ID: 0076
SCAN ID: 0275
Platform Codes: C1
Engine RPO Codes: L05
Engine Displacement (L): 5.7
Transmission RPO Codes: M30
Transmission Type: AUTO
Gear Ratio RPO Codes: GT4
Emmission RPO Codes: +NB6
Emissions Catagory: CAL
GVWR Ratings:
Broadcast Code: BJDR
Model Year: 1994
Release Date: 06/02/93
EPROM Part Number: 16197394
PROM ID: 7396
SCAN ID: 7415
Broadcast Code: BHMC
Model Year: 1994
Release Date: 07/19/93
EPROM Part Number: 16195493
PROM ID: 5494
SCAN ID: 5505
Platform Codes: C1,C2,K1,K2
Engine RPO Codes: L03
Engine Displacement (L): 5.0
Emmission RPO Codes: +NA5,+NA6
Emissions Catagory: F/A
GVWR Ratings:
Broadcast Code: BJYM
Model Year: 1995
Release Date: 12/21/93
EPROM Part Number: 16200101
PROM ID: 0102
SCAN ID: 0355
Platform Codes: C1
Emissions Catagory: FED
GVWR Ratings:
if you need/want superceded BCCs i can get those as well, just tell me which ones.
Model Year: 1994
PROM ID: 4632
SCAN ID: 4705
Model Year: 1994
PROM ID: 5896
SCAN ID: 5925
GVWR Ratings: CTF
Model Year: 1995
PROM ID: 2136
SCAN ID: 2125
Platform Codes: M1
GVWR Ratings: VD1
Model Year: 1995
PROM ID: 0076
SCAN ID: 0275
Platform Codes: C1
GVWR Ratings:
Model Year: 1994
PROM ID: 7396
SCAN ID: 7415
Model Year: 1994
PROM ID: 5494
SCAN ID: 5505
GVWR Ratings:
Model Year: 1995
PROM ID: 0102
SCAN ID: 0355
Platform Codes: C1
GVWR Ratings:
Rally Smith
Rally Smith
This be the one.
Model Year: 1995
PROM ID: 0102
SCAN ID: 0355
Platform Codes: C1
Emission RPO Codes: +NA5
GVWR Ratings:
Thanks again.
Model Year: 1995
PROM ID: 0102
SCAN ID: 0355
Platform Codes: C1
GVWR Ratings:
Thanks again.
Rally Smith
Rally Smith
Sir, yes Sir.
This may seem like a silly question, but where would be a good place to start as far as tuning goes?
Do I need a good Data Log to view the VE, BLM's, etc before I do anything? Has anyone here used Data Master to Data Log and know's how to decifer the info into something useful?
When I have the Auto Prom hooked up to my truck and it is running is my truck running off of the bin file I have installed?
Email:rsmithjr25@yahoo.com
Rally Smith
Rally Smith
So I got the Auto Prom and ALDL hooked up together. When I went to data log and Emulate together, I pulled up the dash view and the RPM's & TPS were not working. Any Idea on why that would be?
When I was Emulating I tried messing with the closed spark table but nothing happened. I want to try and smooth out my idle first to get the hang of this before I jump in too deep.
Rally Smith
So I was trying to Emulate last night and adjust my idle. I timed my truck and I have it set at 2 deg. BTDC. I read somewhere that the ECM should be adjusted to the same as well. I tried adjusting the Initial Spark Advance in Tuner Pro, but nothing changed. So I tried making a big change and nothing happened. I tried adjusting the Initial Spark Advance and nothing changed.
My truck has a stumble in the idle at times and it drives me nuts! Where would be a good place to start on smoothing that out? I have already done a complete tune up on it. Plugs, Wires, Cap & Rotor.
