Downloaded new XDF and now values are all jacked up
David Claflin
Post by David Claflin »
I noticed the XDF for GUFB is newer then what I had loaded so I downloaded and used it only to find all the values in most items like MAF are all the same from top top to bottom, in my bin and even the stock A9L bin. When I reinstalled the old XDF everything was back to normal.
Is there something I was supposed to do differently with the new XDF?
Thanks!!
1990LX 306, 77MM Pro-M, 75MMTB, Holley SystemaxII, Neil Erickson ported Edelbrock performers, 1 3/4"BBK longtubes, T5, 3.73's, Mach 1 disks, 18.5 city 27 hwy, Moates chip, Tuner pro,334RWHP/351RWTQ
Are you using a 56k or 64k bin file? It could be this if you altered the old xdf header to work with 56k bins.
David Claflin
Yes, mine is a 56K, but even the stock A9 bin does the same thing?!?
Right, it sound like you altered your last xdf, see this thread http://tunerpro.net/forum/viewtopic.php?t=530 for more on this subject.
David Claflin
That fixed it thanks, I printed that sheet out and put it in my folder so I'lll have it in case this comes up again.
