Whats the difference between tuner pro and tunerpro RT? is it actual software differences or just paid version has free/faster support?
I just used pcmhammer to read entire pcm and save stock bin.
then used tunerpro with the 2156 XDF to modify that Bin, delete vats, enable electric fans and delete Dtc codes.
It saved as new modified bin, but at time of saving it gave me a warning error code saying;
Error-one or more checksums could not be updated. check checksum adresses etc, for validity
Im told i shouldnt write this to my PCM until this is fixed.
whats goin on here?
Newbie using Tunerpro; versions?
Re: Newbie using Tunerpro; versions?
Im having the same problem did you ever get it fixed ?
