2015 GM AFM Disable
dan98
2015 GM AFM Disable
Post by dan98 »
Does TunerPro work on 2015 and up GM pickups to disable AFM? Or are the trucks to new?
Dan
V8fan
Re: 2015 GM AFM Disable
Post by V8fan »
Tuner pro needs XDF to work with bin (and u need hardware to reflash ur ECM)
If someone willing to share it cuz new cars has much more complicated OS and it takes a lot of knowledge to make XDF from raw data
lyly19
Post by lyly19 »
Hi Dan,
TunerPro itself doesn’t natively support newer 2015+ GM pickups for AFM (Active Fuel Management) disabling — those trucks typically require more advanced tools like HP Tuners or EFI Live due to their updated ECUs and encryption. So unfortunately, they're a bit too new for TunerPro alone.
Lyly Brown Crazy Cattle 3D
