non responsive when resuming from sleep mode
scott0999
Post by scott0999 »
when I get done datalogging I close the screen on my laptop. it is on the aldl setup screen when I do this
then when the laptop comes back up from sleep mode, tunerpro is unresponsive to the point I have to do a hard shutdown.
its a dell latitude cpx laptop with a p3-600, 512 ram, windows xp home sp2, all updates
im running 4.14.0030
'94 Cavalier Z24 3400 Turbo 5 spd running $8F 39# injectors 7730 ECM
Not a TunerPro bug (there's not much for TunerPro to do in this situation). This is likely an issue with a device driver installed on your system.
scott0999
Post by scott0999 »
if just tunerpro is open and im not on the aldl setup screen it resumes normally.
no biggie, I can just close the aldl screen before putting it to sleep mode
