Kawasaki Ninja 300 and Z300 Denso new XDF
New TunerPro XDF for Kawasaki Ninja 300 my2012 and Z300 model year 2015 with ECU Denso.
Supported motorcycles:
Ninja 300 my2012 39cv
Ninja 300 ABS my2012 39cv
Z300 my2015 39cv
Z300 ABS my2015 39cv
Available maps:
- Fuel: fuel by RPM and pressure cyl 1 (map A+B), fuel by RPM and pressure cyl 2 (map A+B), fuel by RPM and throttle cyl 1 (map A+B), fuel by RPM and throttle cyl 2 (map A+B), fuel cut off, target lambda.
- Ignition: main spark advance neutral, main spark advance cyl 1 (map A+B), main spark advance cyl 2 (map A+B).
- Secondary Throttle: secondary throttle (divided by gear and map A+B).
- Cooling Fans: fans control.
- Special Functions: speed limiter, RPM limiter – ignition, RPM limiter – fuel.
Price 40 euro
Post: https://oldskulltuning.com/kawasaki-nin ... erpro-xdf/
