Lancia Delta HF integrale defintions at prograle.org
Discuss all other manufacturer-specific tuning topics here. Request definitions, discuss parameters, etc.
raparici
Post by raparici »
I created the definition files for the 8v, 16v and evoluzione ecus. They will be enhanced with more corrections in the future. Also I plan to create the 8vkat and Evoluzione Kat ones asap.
You can find them in the download section of http://prograle.org
kind regards,
Ruben
Hi Ruben -
This is most excellent! Thanks you very much, and please keep me informed of future progress. Next time I edit the main web site I'll add a link to your site for definitions.
Thanks again!
Mark
Juan AR155Q4
Post by Juan AR155Q4 »
Hi, sory for pulling up this thread, but I´m looking for an Alfa 155 Q4 definition file.
Is the same as one of Delta´s?
Turbochris
Post by Turbochris »
As Rubens wrote:
"You can find them in the download section of http://prograle.org"
Basicaly identical and excangeable with Lancia Delta Integrale 16V Cat,
Lancia Delta HF-HPE and Fiat Coupe.
But watch for cars with/ without imobilizer!
You got to do some home work...
Chris
Juan AR155Q4
Chris
Thanks, didn´t knew that were exchangeable.
Is this exchangeable with Fiat Tipo 2.0 16v?
Turbochris
No, sure not.
You have to put a little own work in this specific ECU. This is very easy now, compared to what we had on tools and information about it a few years ago…
But the principle the Weber ECU´s work on is similar on all versions.
So all what you have to do, is to look at the XDF file for the Lancia Delta HF 16V and compare the maps to the ones you find in your 16V bin. Then you can easily modify the XDF for your own ECU.
There are some Weber ECU´s that "run backwards", but with some logical thinking you can change that in a minute too.
The Weber IAW ECU I refer to are the ones used on Fiat, Lancia (and the Alfa 155Q4) twin cam engines. Take a look at the Prograle forum, that should help you to get along with your ECU.
Chris
