Checksum error when saving bin files in tunnerpro.
Hello everyone. I'm new her. I tried tunnerpro today. Re-saved a virgin file from my daily driver, with no changes and received a checksum error. Tried rewrite with. Pcm hacker and received file currupt message. Any ideas? Thanks
Re: Checksum error when saving bin files in tunnerpro.
Providing more information such as the binary file and xdf definition details will help people see if they can assist you.
Thisi s the message that I receive.
- Screenshot_20210118-074745.png (17.7 KiB) Viewed 10390 times
- Screenshot_20210118-074816.png (73.17 KiB) Viewed 10390 times
- Screenshot_20210118-074723.png (115.22 KiB) Viewed 10390 times
i had similar checksum errors when saving bin after making changes.
i was given a a different tuning software which included a checksum file fixer.
If i remember correctly, it seems to work but only on a virgin set of changes.
like if you make changes to the stock bin and save it successfully before, you cant start with that changed bin and make more changes as the checksum fixer wont work twice.
you have to start over with a fresh copy of your stock bin, make the old changes , add new changes and fix with checksum fixer.
i think the tuner, checksum fixer was called tinytuner
if i get some help with some newbie questions i posted in order to make some more changes to my stock bin, i will be doing this whole process over myself and will verify im remebering it correctly
