E6 definition
bigburb
E6 definition
Post by bigburb »
I'm currently using the E6 (93 CK trucks) definition provided by this website (could be moates though), however i went to the tunercat website and saw their definition has a few more values in it (which i would appreciate having). rather than buying tunercat is there anyway i could manually add these values? how would i do that?
AMATURE
honken
Post by honken »
Take the aldlstuff.zip and find your stream look if you misses somthing
If you find somthing ad it in the aldl setup.
http://www.moates.net/fileman/index.php ... efinitions
bigburb
Post by bigburb »
i see, what i mean is the bin definition.
AMATURE
honken
Post by honken »
Then you need a hack of the E6 and create the table or constant you want
if you dont find any other xdf file somwere.
If you'd like to buy the TunerCat definition, it can be made to work with TunerPro. Otherwise you'll need to use the E6 hack and add the items to he XDF yourself.
