baud rate for ALDL
VR-4-PLAY
baud rate for ALDL
Post by VR-4-PLAY »
Just wondering if it would be possible to have the baud rate for ALDL user adjustable?
Most 1G DSMs are at 1953 baud, and i think this is why i cant get the ALDL feature to work on my VR4.
I dont mind testing anything if u want :wink:
milesf
Post by milesf »
I second this, I'd love to see the ability to log and tune with one piece of software. I'm not much of a programmer, so I'm unsure of the difficulty involved in implementing 1953 baud, but I'm very sure it would be widely appreciated by the dsm community. If there's anything I can to do help just ask..
Miles
Yes, the next version supports this directly. For ADS files (currently), you can hand edit the ADS to use the baud rate you desire.
That said, TunerPro will not support your Nissan yet. This is coming in a future
raparici
Post by raparici »
I second this feature, a speed of 7812,5bps would offer many possibilities in italian cars ;-)
regards,
Ruben
Good to know. 7812.5 is an impossible baud rate. If it's converted to RS232, most likely the port will need to be opened up at something a little more round.
raparici
Post by raparici »
Hi Mark,
Yes a round up won't be a problem as soon as windows works fine with these rare speeds.
regards,
Ruben
Gracias Ruben. ¿Qué clase de coche estás templando?
raparici
Post by raparici »
Hola Mark,
Los coches que suelo tocar son los Lancia Delta HF integrale (2 litros Turbo 4x4) que ganaron 6 WRC consecutivos (1987-1992). Ver:
http://www.clublancista.org/albums/view ... me=album45
Aqui una foto mía en el banco trabajando en uno:
http://www.clublancista.org/albums/view ... OTOS_4_053
un saludo,
Ruben
¡Cool! =) ¿Has estado utilizando TunerPro para templar tu Lancia?
raparici
Post by raparici »
No, de momento no, todavía estoy haciendo los definition files. Necesito hacer 4 definition files para poder trabajar en todas las versiones de ecu del modelo. Lo bueno es que estos definition files también serán útiles para algunos Fiat, Alfa Romeo y Ford Cosworth ;-) dispongo de los hacks para hacerlos pero me ha salido un problema en una tabla. Si tienes tiempo te la mando para ver si encuentras un fallo en el definition o el bug en tuner pro.
un saludo,
Ruben
Sure, send everything my way and I'll take a look.
