Hi, I need a ecu or xdf definition file to tune this ecm:
 1227749 (87 - 90 Sunbird, Grand Am), 2.0L, LT3 Turbo
I'm equiped with TunerproRT and APU1 so my question is:
Can I use any $58 definition?
 On TunerCat website I can see there is $58 for Syclone/Typhoon and $58A for Sunbird 2.0L, LT3 Turbo?
I dont want to buy TunerCat since Im use to TunerProRT so Is there a $58A for TunerPro?
What is the difference between $58 and $58A ? (only num. of cyl?)
						7749
58A is for a 4 cyl, 58 is for 6 cyl. As far as  I know, they are otherwise equal in terms of code.
If you own the TunerCat 58A TDF (definition file), you can use it to create a TunerPro definition. If you need help with that, contact me offline.
