Hi guys,
Working on building tables for a setup right now that has them available on one vehicle model, but not this one.  I can open both tunes and compare them directly, but some tables have only one cell vs. 10 that I can use (and dearly need).
Can build the tables and they import into hptuners new User Defined Functions, but the cells are full of useless values that I cannot change to what I need specifically.
While messing with things, if I change the hex address for the table, the values in the cell change.  I can scale the entire table by adding a formula in the conversion tab, but that gets maybe one cell out of many at the value that I need.
Does this mean I need the specific hex addresses for those tables?
						Cell values from .xdf to hptuners
