NEED A RELIABLE BIN FOR 90 IROC-Z 5.7L TPI
1227730 IROC
Post by 1227730 IROC »
WHERE IS A RELIABLE SOURCE FOR BIN FILE ON 1990 IROC-Z 5.7TPI ECM P/N 1227730 ?
THE QUEST FOR SPEED CONTINUES...
Try the http://www.gearhead-efi.com site.
Also, could you please turn off the 'caps lock' when typing :D
1227730 IROC
dex wrote:Try the http://www.gearhead-efi.com site.
SORRY CAPS LOK IS STUK.
THANX FOR THE INFO ILL TRY IT.
1227730 IROC
[quote="dex"]Try the http://www.gearhead-efi.com site.
Also, could you please turn off the 'caps lock' when typing :D[/quo
NO BIN FILES FOUND. NEED TO LOOK SOMEWHERE ELSE.
There are loads of bin file on the site, do you mean you cannot find the one you want?
1227730 IROC
dex wrote:There are loads of bin file on the site, do you mean you cannot find the one you want?
FOUND THE RIGHT BIN FILE.
CANT FIND BIN DEFINITION. FOUND Super_8dm2.ecu ON TUNERPRO WEBSITE BUT THIS IS NOT .XDF LIKE THE PROGRAM WANTS.
THE TUNERPRO WEBSITE SHOWS Super_8dm2.ecu AS THE CORRECT BIN DEFINITION FILE. LOST AGAIN.
