Rieju Aventura 500 Bosch MSE6.0 ecu tuning
Posted: Sun Apr 14, 2024 10:49 pm
by OldSkullTuning
New TunerPro bin definition files (xdf) for Rieju Aventura 500 with engine control unit Bosch MSE6.0 (US6.0).
Also available WinOLS OLSX mappack.
Price 60 euro.
Post: oldskulltuning.com/bosch-mse6-0-tunerpro-maps-for-atv-and-bikes
Available maps:
- Fuel: nominal lambda for component protection, lambda at WOT, target lambda at partial load, lambda during warm up by engine and coolant temperature, lambda limit for combustion, injection correction factor by effective injection time.
- Ignition: ignition advance-angle characteristic map, optimal ignition advance-angle map, ignition advance-angle correction by engine and coolant temperature.
- Idle: idle engine speed by engine temperature.
- Throttle: standardized air mass flow through throttle valve, desired throttle angle, throttle position sensor.
- Temperature: calculated exhaust gas temperature.
- Air Calculation: volumetric efficiency, map for calculation of nominal charge.
- RPM Limiter.
- Lambda deactivation.
