I've found an 8D definition (XDF) file that I've been using on TunerCat page but I can't get the one on the TunerPro page to load properly.
It is listed as a "Super 8dm2.ecu" but Tuner Pro doesn't like the file???
Main thing I'm looking for is constants to update my trip computer. I'm running 42lb injectors & changed the constant for injector flow which works great but someone thought there might also be a constant to adjust the trip computer as well.
The super_8dm2.ecu file loads just fine. How are you loading it? You must use the XDF->Import->ECU menu option, or drag and drop the ECU file into the main TunerPro window.
