Hard coded 300 category limit causes issues. Expand limit?
hassmaschine
PostPosted: Fri Jul 24, 2015 8:20 am    Post subject: Hard coded 300 category limit causes issues. Expand limit? Reply with quote
I've been working on generating an XDF for a newer BMW computer. I've got it pretty well nailed down except a BIG issue.
Currently, TunerPro can only handle 300 categories. The way this ECU is broken down there are about 1,200 functions and 9,000 maps/curves/constants. The best way to organize all the maps etc. is by "function", which is equivalent to a TunerPro category.
However, hen you go past the 300 category limit, any maps etc. set to those categories loop around to the beginning. This of course makes a mess of the file.
Right now my only real option is to break it up into multiple XDFs, but that is a bit of a pain. I'll have to figure out exactly where the breaks between functions/subfunctions are so I don't surpass the 300 limit in any given XDF.
It would be really great if the hard coded limit was significantly higher - even if more than 300 weren't selectable in the drop down boxes, if it could at least internally read them correctly I could do everything with 1 file.
Other than that it doesn't seem to mind having 9,000 defined characteristics! Smile
Back to top
Display posts from previous:
Page 1 of 1
Jump to:
