Hi all,
last night i manged to fit 2timer from moates.net to run 2 maps on the ECU, in short am trying to do a launch control, i managed to set 2 bins with same data, but with different rev limits, and it works, now i can make the car rev on 3500RPM and then switch it to normal to start in street drag, and its giving good results, but i need help with 2 things that i couldn't figure out so far
1- when the engine hit the rev limit on 3500RPM its sounds like slow cutting, not like the cutting at 7000RPM, so can i make it faster like increasing the frequency of the cutting or something like that?
2- the default rev limit cuts fuel, can i cut spark instead of fuel?
* am working on the 405 ECU XDF, with my bmw m50 2.5l non-vanos engine
thanks in advance and hope to hear a feedback soon i will post a vid soon
Motronic + 2timer
if you work the code to cut spark instead of fuel, expect to blow up a few mufflers... cutting both would be the best possible route since it won't leave a large amount of combustible fuel and oxygen in the exhaust waiting for a cylinder to go live and ignite it all. but i don't know how much of a pain that would be to get working in the ECM.
and i assume the ECM uses a hysterisis for rev limit routine? if so, set the re-enable speed closer to the kill speed and see if that has any good results.
I created that XDF 405 so you got to ask big daddy. Reason why the cut is slow is because it cuts all injectors at the same time, where ideal would be to cut 3 out of 6 but that will require recoding the code and I am not going to do that, I already provided so much information that no one else came even close.
