Hey Mark,
I am trying to use the 1227747_42.ads for data reading and it is incredibly slow. ex...if I blip the throttle to rev it will rise and fall in actual RPM before it shows on the dashboard as a change. All other parameters do the same thing.
Is it the speed of the ECM or do I need to change something on my laptop?
Thanks much!
-Kenny
1991 GMC Jimmy with TBI 350...datastream issue or me?
- Six_Shooter
this thread is a bit old but i think both you guys have a 160 buad ECM. You should upgrade to a 8625 ecm, it has a 8192 baud output for data logging, so it should be much more responsive. If you look on thirdgen.org you will see a lot of guys upgrading to the 8625 ecms. It requires a bit of wiring work, youll need to make an adaptor for your ecm connectors to match an 8625 ecm connector.
- Six_Shooter
Yep, have seen that, not an option for the application I'm using a 7747 in.HarpSeal1 wrote:this thread is a bit old but i think both you guys have a 160 buad ECM. You should upgrade to a 8625 ecm, it has a 8192 baud output for data logging, so it should be much more responsive. If you look on thirdgen.org you will see a lot of guys upgrading to the 8625 ecms. It requires a bit of wiring work, youll need to make an adaptor for your ecm connectors to match an 8625 ecm connector.
