new xdf for OD mask
new xdf for OD mask
Need to know how to create the info needed to build a new xdf item and where to insert it. Was able to configure new aldl to insert WB 02 into datastream but had decent instructions on how to do it. Also I am moderately to totally computer illiterate as far as code & hex. What I need is a BLM min rpm to select from but my current xdf only has max.
You need the od hack:
http://www.moates.net/fileman/index.php ... nd%20Hacks
Its the ODzip.
With this you do a xdf thats lets you se the tables,constant and flags in the bin file you have.
If you look at the OD hack you dont have the BLM min rpm.
Im realy dont now wath you want to do with it.
Its the ODzip.
Thanks for the direction. Buzzed through the BJYA OD hac & if I'm understanding it correctly, there is no BLM min rpm . Is that why it's not in my tunerpro XDF ? Also I noticed that there were items L48EE:FCB 3 ;idle closed loop int window, & L48F0 : FCB 90 ;min idle BLM that aren't in my XDF either. Can I just go to the hex editor in tunerpro & adjust these manually,& if so wich #s do I change?
