Hi all,
A friend to crash a 2019 dodge ram with HP tuner.
no more communication to reinject the original, after reading with another tool (file.bin) all the flash part of the dump is missing.
A solution ? someone have the dump in question in .bin? or can you transform the original file attached the.HPT INTO .BIN?
liens fichier: https://mega.nz/file/cGBRFKhK#Qu5H4E_4A ... ZfOUmTELQE
Thanks in advance to all for your help
2019 dodge crash problem
Re: 2019 dodge crash problem
I think your friend should Check for backup files. If your friend made a backup of the original file before attempting to modify it, you may be able to use the backup file to restore the ECM. Check the computer or storage device where the backup was saved to see if it is still available.
