I am playing with a '90 s-10 pu with 4.3 v6. I have the Moates apu1 package and tunerpro rt. I downloaded the TP 1227747_42.ads file to my laptop and hooked it up to the aldl yesterday for the first time. It records data but I have 3 things that seem wrong. The temp when cold starts out at 184° C, and drops down to 47 C as it warms up, but my dash temp gauge reads right. Could there be a multiplier inverted in the definition file?
Also the O2 reading zigzaggs from top to bottom constantly. I dont know what it is supposed to do, but that doesn't seem right.
Plus I was unable to record a data log. It kept saying something like 'unable to create the data log'. I tried to create one from the preferences page, but got the same result. Any suggestions what to do?
Scott
1227747 $42 ALDL def
I spend most of my money on beer, women, and racing. The rest I just waste.
OK, I understand two of my problems. The O2 reading is supposed to constantly zigzag up and down. And recording a data log requires naming a new log first, then tunerpro automatically sees it as the working file.
I still don't know why my temp reads backwards. I installed winADLD at someones recommendation, but that is a whole different program and I want to stay with tunerpro.
Also my truck is a 90 s-10 4.3 with manual trans, chip program APAA. I have not seen this particular combination in any of the ecm web info I have found. Could that explain the reverse temp?
So I either need a different aldl definition file to try, or I need to edit the coolant temp equation in the current .ads. Anyone have a working equation?
