Bosch Motronic M3.3.1 - 1211 Error
Posted: Wed Aug 12, 2020 11:41 am
by kab343
I've got an issue with a Bosch Motronic M3.3.1, it keeps throwing a 1211 error but the car starts and runs absolutely fine. Can anyone give me some tips or tricks on how to track down what could be causing it? The ECU itself doesn't appear to have failed as it is running fine, it seems like it maybe something like a checksum error?
Re: Bosch Motronic M3.3.1 - 1211 Error
Posted: Thu Aug 13, 2020 1:00 am
by biela
Hello
https://www.e30zone.net/e30wiki/index.p ... ault_Codes
1211
DME Control Unit
DME, Motronic computer, related fault - which may indicate problem with car computer itself. Delete any stored codes and perform following test: Start the car and let it run for 30 seconds; Turn off car and let it sit for another 30 seconds; Perform diagnostic test again; If the same flash code re-appears DME should be replaced
Anyway, have you tested another bin file or ori chip?
Posted: Thu Aug 13, 2020 1:29 am
by kab343
I've cleared the code a few times by disconnecting the battery, but I'll try your method to. The code comes back after 2 - 3 starts.
No haven't tried a different bin file or chip, how could I go about trying either?
Posted: Sat Aug 22, 2020 10:58 pm
by olafu
M3.3.1 calculates checksum after ignition is switched off, i think it is pretty last thing before the main relay is released. But if you put ignition back before calculation is performed, the fault code doesn't appear.
Some chip tuners leaves wrong checksum for workshops etc.., for a sign of modified BIN. ...if checksum error doesn't affect anything.
Posted: Sun Aug 23, 2020 1:43 am
by kab343
Ok that makes sense, is there an easy way for me to check my checksum? I would prefer to remove the error if I could easily. That way when the check engine light comes on I know it's for something serious!
Posted: Sun Aug 23, 2020 7:40 am
by olafu
In theory it is possible to get BIN out from ecu through K-line, but easiest way is take EPROM-chip out and read it with eprommer. That way you can check the checksum and compare bin to original or other original one. There is several different stock chips in M3.3.1, depends on which car and engine it is in.
Posted: Sun Aug 23, 2020 12:28 pm
by kab343
Ok I'll look to remove the chip. Any recommendations on a good eprommer to use?
The car is a 1993 BMW 325i has the M50B25TU motor in it.
I have a spare DME now, so can check that one also.
Posted: Mon Aug 24, 2020 3:43 am
by olafu
I have TL866ii programmer. Works fine.
Posted: Wed Aug 26, 2020 10:28 am
by mahdi93
guys do you know or have any software to diag codes from thoose obd1 ecu's ? and if i need any interface ??
